Thông tin chung
Chi Tiết Ngắn Gọn
- NƠI XUẤT XỨ:GUANGDONG, CHINA KÍCH:2131*1052*35MM
- NHÃN HIỆU:LONGI NĂNG LƯỢNG MẶT TRỜI TỔNG TRỌNG LƯỢNG:29.5KG
- SỐ MÔ HÌNH:LR4-72HBD-420M KHẢ NĂNG CHỊU LỰC:± 5%
- LOẠI:KÍNH ĐÔI NĂNG LƯỢNG MẶT TRỜI BẢNG ĐIỀU KHIỂN HỘP NỐI:IP68 ĐÁNH GIÁ, 3 ĐIỐT
- ITEM NAME:LONGI NĂNG LƯỢNG MẶT TRỜI 420 W CÁP:4.0MM2, 300MM CHIỀU DÀI
- THỦY TINH:KÍNH KÉP, 2.0MM TEMPERED GLASS KẾT NỐI:MC4 TƯƠNG THÍCH KẾT NỐI
- DI ĐỘNG LOẠI:6 INCH MONO NĂNG LƯỢNG MẶT TRỜI DI ĐỘNG KHUNG:ANODIZED NHÔM HỢP KIM, BẠC
- BẢO HÀNH:25 NĂM CÔNG SUẤT ĐẦU RA ĐẢM BẢO
PORDUCT THÔNG TIN CHI TIẾTDỮ LIỆU CƠ KHÍLOẠI TẾ BÀO:5BB MONO NĂNG LƯỢNG MẶT TRỜI DI ĐỘNGSỐ DI ĐỘNG:144 (6*24)KÍCH THƯỚC:2131*1052*30MMMẶT KÍNH:KÍNH KÉP, 2.0MM TEMPERED GLASSBACKSHEET:KÍNH KÉPHỘP NỐI:IP68 ĐÁNH GIÁ, 3 ĐIỐTKHUNG:ANODIZED NHÔM HỢP KIM, BẠCKẾT NỐI:MC4 TƯƠNG THÍCHCÁP:4.0MM ²/12AWG, 300MM CHIỀU DÀITIÊU CHUẨN KIỂM TRA ĐIỀU KIỆN:AM1.5 100 MW/CM 25 °CDỮ LIỆU ĐIỆNMÔ HÌNHLR4-72HBD-415MLR4-72HBD-420MLR4-72HBD-425MLR4-72HBD-430MCÔNG SUẤT ĐỈNH WATT-PMAX (W)415420425430CÔNG SUẤT TỐI ĐA ĐIỆN ÁP-VMPP (V)40.640.841.041.2TỐI ĐA ĐIỆN HIỆN TẠI-IMPP (A)10.2310.3010.3710.44MỞ MẠCH ĐIỆN ÁP-VOC (V)49.049.249.449.6NGẮN MẠCH HIỆN TẠI-ISC (A)10.8910.9611.0211.09MÔ-ĐUN HIỆU QUẢ (%)18.518.719.019.2SẢN LƯỢNG ĐIỆN DUNG SAI (W)0 ~ + 3STCBỨC XẠ 1000 W/M², DI ĐỘNG NHIỆT ĐỘ 25℃, KHỐI KHÍ AM1.5NHIỆT ĐỘ HOẠT ĐỘNG-40 ~ + 85℃TỐI ĐA HỆ THỐNG ĐIỆN ÁP1500 V DC (IEC/UL)MAX LOẠT CẦU CHÌ ĐÁNH GIÁ20AHỆ SỐ NHIỆT ĐỘ CỦA PMAX-0.37%/℃HỆ SỐ NHIỆT ĐỘ CỦA VOC-0.30%/℃HỆ SỐ NHIỆT ĐỘ CỦA ISC0.06%/℃ĐẶC TÍNH SẢN PHẨM
1. MẶT TRƯỚC HIỆU SUẤT TƯƠNG ĐƯƠNG VỚI THÔNG THƯỜNG THẤP NẮP MONO PERC.
-CAO CHUYỂN ĐỔI MÔ-ĐUN HIỆU QUẢ (LÊN TP 19.4%).
-NĂNG LƯỢNG TỐT HƠN NĂNG SUẤT VỚI TUYỆT VỜI THẤP IRRADIANCCE HIỆU SUẤT VÀ HỆ SỐ NHIỆT ĐỘ-NĂM ĐẦU TIÊN ĐIỆN SUY THOÁI <2%.2. BIFACIAL CÔNG NGHỆ.
CHO PHÉP NĂNG LƯỢNG BỔ SUNG THU HOẠCH TỪ PHÍA SAU (LÊN ĐẾN 25%)3. GLASS/THỦY TINH CÁN
ĐẢM BẢO 30 NĂM ĐỜI SẢN PHẨM, VỚI HÀNG NĂM ĐIỆN SUY THOÁI <0.45%, 1500 V TƯƠNG THÍCH ĐỂ GIẢM BOS CHI PHÍ.4. SOLID PID KHÁNG
ĐẢM BẢO BẰNG NĂNG LƯỢNG MẶT TRỜI DI ĐỘNG QUÁ TRÌNH TỐI ƯU HÓA VÀ CẨN THẬN MÔ-ĐUN BOM ĐỂ LỰA CHỌN.5. LÀM GIẢM ĐIỆN TRỞ GIẢM CÂN
VỚI THẤP ĐIỀU HÀNH HIỆN TẠI6. NĂNG LƯỢNG CAO HƠN NĂNG SUẤT
VỚI HOẠT ĐỘNG THẤP HƠN NHIỆT ĐỘ7. LÀM GIẢM ĐIỂM NÓNG RỦI RO
VỚI TỐI ƯU HÓA ĐIỆN THIẾT KẾ VÀ HOẠT ĐỘNG THẤP HƠN HIỆN TẠI.ỨNG DỤNG
